Hesitation at idle
Old Nov 13, 2013 | 3:40 PM
Schoolersteve's Avatar
New User
Awaiting E-mail Confirmation
Default Hesitation at idle
Hi I have a 02 silverado 4.8 I recently did transmission pan gasket and oil change new spark plugs spark plugg wires and valve cover gasket, and coolant flush.
Got truck all put back together and it was making a small faint ticking at engine very faint but also a hesitation at idle runs fine just when idling in park or sitting at stop light a hesitation at motor.
So after reading forums I realized I power washed the engine and heard that was a bad idea on these trucks because of the knock sensor, and my code reader picked up code p0332 wich is knock sensor. So I replaced both knock sensors they were badly corroded and had water in them where they sit so I got intake manifold put back together and nothing still hesitating but the service light is gone I've also tried checking plugs a few time and check idle control sensor and cleaned throttle body plate.
Only thing might be left is I got auto light plugs please any help is my moms truck thanks
Old Nov 13, 2013 | 4:22 PM
Welcome to the forum...
You might try a couple bottles of fuel injector cleaner in the tank and a fresh tank of gas...
Old Nov 13, 2013 | 4:28 PM
New User
Thanks I did that with injector cleaner in the tank I also cleaned injectors when I did the knock sensors something I forgot was before the service light cam on my code reader picked up a low spark on number 8 but I checked it and 7 and 6 and they all good went picked up ac deco plugs gonna switch from the auto lights but not sure if that will matter since it runs fine just studders at idle
Old Nov 13, 2013 | 4:34 PM
Might also want to check and clean the throttle body and the IAC valve...
Old Nov 13, 2013 | 4:45 PM
New User
I did both of those but will look at them again
Old Nov 14, 2013 | 5:02 PM
New User
D d that again no luck
Old Nov 14, 2013 | 6:12 PM
New User
Let me Also say maybe not a engine hesitation more just as light vibration of the engine like in idle if hands on steering wheel u can feel slight vibration like a studder
Old Nov 14, 2013 | 8:29 PM
Tech's Avatar
Because you cleaned throttle body you may need an idle relearn. PCM has been always adjusting over time to compensate for all that buildup that was there now maybe it hasn't learned new position yet for optimum idle efficiency. I'm just throwing that out there cause generally they'll learn just fine on their own without someone having to manually command the relearn with a scan tool.
Old Nov 15, 2013 | 2:56 PM
New User
Ok thx I will rescan and see
rali2000
Apr 3, 2016 1:38 PM
militarydave
Jan 29, 2012 5:44 AM
skongolf
Oct 8, 2010 6:23 PM
dg123
Feb 17, 2008 8:22 PM
monster693
Dec 4, 2007 6:56 PM
