high idle-1997 1500 Silverado, 5spd, 350
Old Oct 4, 2009 | 11:02 AM
spaulmiller's Avatar
Default high idle-1997 1500 Silverado, 5spd, 350
My 1997 Silverado idles very high (12-1500 RPM) at all times, pretty much. Someone mentioned that this may be the TPS causing the ECM to go into a "factory default mode"? Any help? Truck is a daily driver, and I could definitely be getting at least SOME increase in fuel efficiency, if this problem were dealt with. Thanks!
Old Oct 4, 2009 | 8:44 PM
Flying Low's Avatar
Ride of the Month
May 2008
From: Millbrook,Alabama...Slap dab in the middle of God's country
That should have your check engine light on, have your code checked.
My 97 with a similar problem (It was sporatic) was the tps.
Old Oct 6, 2009 | 5:47 PM
geozeke's Avatar
My manual says to test the voltage on the grey wire to ground (with the connector removed from the TPS) and you should have 5.0 volts (with key on). Then, reconnect the connector, and you should have 0.6 volts from the blue wire to ground with the throttle closed, and it should vary to 4.5 volts steadily as you open the throttle. I recently tried this on mine (93) and it worked as described. Manual covers 1988 to 2000 models.
Old Oct 7, 2009 | 12:01 PM
Default high idle help
Thanks to all who've responded with helpful information on this issue. I will replace the TPS asap,and post the results. Hope everyone is having a great day!
in2pro
Dec 25, 2020 11:34 PM
Barrios951
Nov 1, 2014 8:44 AM
K1500Blazer
Site Feedback
Oct 20, 2013 9:57 AM
apgambino
Feb 24, 2011 11:38 AM
caliv0608
Jun 23, 2007 6:57 AM
