Hooking up a GPS direct connection 2011 silverado z71
Old Nov 9, 2011 | 7:00 PM
flrtrader's Avatar
Default Hooking up a GPS direct connection 2011 silverado z71
I just purchased a Garmin GPS and it has to be hooked up via a cigarette lighter for the traffic option to work. Not wanting the plug, and wires trailing across the dash I bought an aftermarket light plug with pos/neg terminals to direct wire into the system. Question is, Is there a blank spot in the fuse block under the hood to run this to? Or even better yet something I can jump into under the dash that will not upset the system, or void any warranties?
Thanks...
Old Nov 9, 2011 | 10:18 PM
EinST's Avatar
One way would be to find a fuse in the I/P fuse block that switches on/off the way you want and then install an add-a-circuit fuse holder.
Old Nov 10, 2011 | 8:06 AM
flrtrader's Avatar
IP fuse block? Under the hood correct?
Old Nov 10, 2011 | 11:19 AM
EinST's Avatar
No, I meant the instrument panel fuse block, driver side of the dash, on the end.
Old Nov 18, 2011 | 2:40 PM
Ryan Colorado's Avatar
I didn't wanna go that route and I ran the wire through the speedo and behind the dash kick panel with the wire showing just enough to plug in. I have full control and it look clean!
Old Nov 18, 2011 | 5:28 PM
EinST's Avatar
Congrats. Thanks for the update.
Dads Toy
Jul 2, 2013 9:50 AM
Dustin98ChevyBlazer
Oct 6, 2010 2:23 AM
selbo
Jan 5, 2010 7:06 PM
landerson
Camaro
Dec 23, 2008 12:03 PM
