How to disable fuel pump 07 NBS
Old Apr 8, 2013 | 9:01 PM
jwruss's Avatar
Default How to disable fuel pump 07 NBS
I need to know if it is possible to disable the fuel pump in a 2007 NBS with a 5.3 AFM. I have already pulled the fuel pump fuse and relay, truck still runs and has correct fuel pressure.
Old Apr 9, 2013 | 11:41 AM
country_09's Avatar
Only way I know of it to unplug the fuel pump itself if the others don't work
Old Apr 9, 2013 | 4:27 PM
But is the fuel pump still running...if so you didn't pull the right fuses and relays.. There can be enough fuel in the line to keep the vehicle running for several minutes at idle if the pump is off...try revving the engine once the fuse is pulled...
Old Apr 11, 2013 | 12:30 PM
jwruss's Avatar
Yes I pulled the right fuses and relay. Had a pressure guage on the line at the time. Found out thru Alldata that the oil pressure switch also has to be unpluged.
mangomanj
Aug 17, 2014 9:51 PM
BRB
Dec 28, 2012 8:34 PM
hunter10220
May 18, 2011 8:37 PM
ericnottelin
13
Apr 13, 2011 9:05 AM
