How does it work
Old Nov 29, 2013 | 11:22 PM
Scooterbonbon's Avatar
Default How does it work
I've acquired a couple spare parts pickups - one has new torque arms and keys in front and spring and block in rear . When I got my 89 1/2 ton someone had adjusted the key bolts way in to lift it up and made me sea sick from all the basketball bounce it had . I've heard the only way to lift is by relocate a frame and re welding in place . My question is what effect does the different keys have as far as lift and ride ?
Old Nov 29, 2013 | 11:40 PM
why don't you just unscrew the key adjustment bolt. you will need to have it aligned after any ride height adjustments are made.
Old Nov 30, 2013 | 12:12 AM
That's what I did do - this parts truck has a lift kit in it and considering swap parts but don't know what that different key does as far as lift by more twisting on bar or how does a different key cause lift with out the bounce it had by screwing the bolt way in
Old Nov 30, 2013 | 9:35 AM
the new keys and adjustment bolt allow more range for the torsion bar to be turned up further (they are angled differently than stock). Turning up the torsion bars to high can make the ride harsh as the control arms hit the bump stops.
Jounce and rebound control is all shock absorber related. the torsion bars do not control this. turning the bar up will force the oem shocks to operation in a range they are not intended for; probably wearing out the shocks. check the shocks for proper operation.
goyakpacking
May 9, 2015 7:51 PM
SabrToothSqrl
Oct 22, 2014 3:35 PM
shant
Feb 23, 2011 9:08 PM
chevykid06
Jan 6, 2007 3:50 AM
