How to get air out of coolant system?
I posted earlier with a 96 silverado blowing cool air when its cold out...Well I replaced the heater core today but its still blowing cold air?? I was told there could be air in the system...How can I burp or get the air out ?
Add a mixture of one-half water and one-half antifreeze to the radiator. Fill it right up to the top. - 2
Fill the overflow/coolant reservoir with the same 50/50 mixture. - 3
Leave the radiator cap off, turn the engine on and let it run until the radiator "burps": You will see the coolant level drop and may see or hear a large air bubble come to the top as the system burps. - 4
Keep an eye on the temperature gauge throughout this process. - 5
Refill the radiator to the top and coolant reservoir as needed. - 6
Put the radiator cap back on. - 7
Note that if the engine runs hot after this procedure there may have been another pocket of air that "burped." Let the engine cool down and then add more coolant to both the radiator and the coolant reservoir.
Professional Mechanic
chevy619
19
February 5th, 2012 8:42 PM
surfandride
January 16th, 2011 10:05 PM
