How to remove INSIDE door panel???
RE: How to remove INSIDE door panel???
pop off the corner piece that covers the mirror mount, pop off the trim around the inside door handle, there sould be about2-3 screws, take your time and find them, they are kinda hidden,pry up the window switch panel, and the door panel should be able to pull straight up and out, if it doesn't come off easily, then you might have missed a screw, believe me it's worth the time to look for them, than to break a piece off your door panel
guvner
April 8th, 2014 9:08 AM
