how would i do this?
Old Apr 12, 2010 | 2:19 PM
country_09's Avatar
Default how would i do this?
I have a 01 silverado z71 with true dual glasspacks....I've been looking around and i've heard a few good things about runnin x-pipe underneath but i don't know where i would weld that up at? Would i weld it up in the middle of the cats and the glasspacks? Also i'm goin to add some longtube headers to go along with it.
Old Apr 12, 2010 | 3:23 PM
nauticstar87's Avatar
After the cats, before the 'packs... You could also do an H-Pipe, cheaper and easier, but not quite as beneficial.
Old Apr 12, 2010 | 8:01 PM
country_09's Avatar
would i just order the x pipe from magnaflow and cut out some of my pipin and replace it with the x pipe? or would i have to re-do the whole pipin underneath
Old Apr 12, 2010 | 8:09 PM
I don't know... It has to be welded, I know that. I'd have to see your set-up in person.
Old Apr 13, 2010 | 9:45 AM
country_09's Avatar
Its true dual....got pipes runnin from each header all the way to the back where it meets the glasspacks then run out the back at a 45 degree angle
http://www.magnaflow.com/02product/s...e=main&id=8487
Old Apr 13, 2010 | 10:26 AM
ffmed6134's Avatar
check the link:
http://www.spintechmufflers.com/x-pi...s/cat_126.html hope this helps
Old Apr 13, 2010 | 3:44 PM
country_09's Avatar
from what i've read it does have some performance benefits...but is it even worth it?
Old Apr 13, 2010 | 5:41 PM
desrtrat's Avatar
yes it does. it will help the exhaust flow from both cylinder banks. i would put it in just behind your trans X member.
Old Apr 13, 2010 | 6:25 PM
country_09's Avatar
is that one from magnaflow a top choice or is there something better?
pjr7269
Feb 23, 2012 3:09 AM
Cavigurl85
Aug 16, 2006 8:33 AM
cturtle
Jul 17, 2006 6:06 PM
Sea Dub
Uplander
Jan 26, 2006 5:00 PM
Sea Dub
Uplander
