Hydraulic Lifters
#11
#12
OHC motors are a little different story, V engines with the cam inside the block you have to remove the intake manifold and take all the lifters out first.
#14
Yeah, your lifters and push rods will fall down into the block if you take out the cam....but you can't even get the cam out without removing them. The lobes would catch the lifters.
So like I said before, here is how you remove the cam -
Remove Radiator
Remove Grille
Remove Valve Covers
Remove Rocker Arms
Remove Push Rods
Remove Distributor (if equipped)
Remove Intake
Remove Lifters
Remove Water Pump
Remove Timing Cover
Remove Timing Chain
Remove Cam
While you have the cam out, its also a good idea to replace the cam bearings. Its not that hard if you have the proper tool for it....but the tool is upwards of 200 bucks and I still haven't found a place that will loan it out.
#15
Honestly, there is no comparison to a generation 1 motor to a generation 3 motor. Everything about the two are completely different.....and with the generation 3 motors it is possible to just pull the cam without knocking out the lifters and pushrods....it would seem like that would happen but apparently its possible with a generation 3 and 4 motor. The only things you remove are grille, radiator, and timing assembly. Any way the original question was merely about reusing the stock roller lifters, not everything it takes to get the cam and components out.....little off track ya think?
1956midwaywagon
February 8th, 2011 1:05 PM
rmitch47
May 7th, 2010 10:55 PM
LTD10
April 2nd, 2008 4:30 PM
