i plan on 305/45/22s on my 07 2500 HD and want to know if they will fit.
I put 285/75/16 BFG M/Ts about 2 years ago and they clear no prolblem. The 305/45/22 are 1/4" shorter but almost an inch wider then the 285s. I have already bought the rims and the offset and the backspacing is right for my truck. I was wondering if anyone knew if the wider tires will rub when i turn sharp?
315 and 325 are actually much closer to 35". I thought 305 was 35" for a long time too, but its almost exactly 34".
Tire Conversion
Tire Conversion
I do not have a lift on my truck, but i am thinking i might have to put a leveling kit on the front end to clear the new tires. On the specs for the 305/45/22 Nitto Dunegrapplers i am looking at buying are 32.72" high and 12.05" wide. The specs on my BFG 285/75/16 M/Ts are 33.1" tall and 11.3" wide. The only problem I have with the 285s rubbing is they sometimes hit the rubber front inner fender wells when I am turning sharp and the susp. is flexed.
