i wanna elevate my ride and i need help!
i have an 05 1500 lt. I'd like to lift it up about 3-4 inches. i dont really have alot of money left now that im buying rims and tires. someone mentioned to me body blocks and tortion bars... am i on the right track here. any info is much appreciated, thanks.
well you could crank the torsion bars and add 3" blocks on the rear axle.. or add a 3" body lift ..if u crank the torsion bars you have to get a alignment and the ride will stiffen up
is it 4wd or 2wd? because if it's two wheel drive it's not torsion keys, its coil spring spacers I think. and that combined with a 3 inch body lift will sit you up around 4-5 I believe
hoppyg
November 13th, 2014 7:17 AM
