idle problem
Old Jun 9, 2010 | 3:18 PM
gotstylez's Avatar
Default idle problem
ok i have this problem now that when i start it up it idles high around 1000 rpm warmed up or not...it also bounces up and down from about 750 to 1000 rpm... didnt do this befor i did the eletric fans and seafoam...... anybody know whats wrong
Old Jun 9, 2010 | 4:28 PM
maxxman04's Avatar
dirty idle air control valve, dirty egr, dirty air filter, maybe vacuum leak
Old Jun 9, 2010 | 7:42 PM
gotstylez's Avatar
i was thinking vaccuum leak too..bu i did unplug my egr when i was doin my fans to find out the senser was too small.so ill clean em n find out
Old Jun 9, 2010 | 8:04 PM
MDTAHOE's Avatar
Professional Mechanic
Is the factory coolant temp sensor still installed or did the fans come with a new one? Did you splice into the wires to the coolant temp sensor? Do you have a scan tool that shows data?
Old Jun 9, 2010 | 8:43 PM
gotstylez's Avatar
factory temp sensor is still there. and i dont have a scan tool and i didnt splice into any wires. all i did was remove the fan and the shroud and put the eletric fans on there. and i just found a fuse that comes on when i turn the ign. on so the fans come on when the ign is on. the sensor that came with the fans is tool little
Old Jun 9, 2010 | 9:07 PM
MDTAHOE's Avatar
It MAYBE keeping the engine too cool. Keeping it in open loop. Try disconnecting the fans. With out seeing data it will just be a guessing game.
Old Jun 9, 2010 | 9:47 PM
gotstylez's Avatar
true..i never thought about that.. im going to re-wire them this weekend.. and im gonna try to find a hole in the firewall so i can just use a switch.. and i hope that willl fix the prob. if not you guys will hear from me again lol
Old Jun 9, 2010 | 10:14 PM
gotstylez's Avatar
the weird thing is i just drove it.. it had good idle lol.. its weird becuaseit did the 1000 rpm idle for 2 days or so..and also i forgot to mention it had hard and high RPM shifts from 1-2 and 2-3..it stopped that too..
Old Jun 10, 2010 | 4:05 PM
gotstylez's Avatar
well i got it scanned today from a buddy of mine i go mudding with hes a pro. mechanic. he says it could be a fuel relay or the fuel pump..does it sounds right to you?
Old Jun 15, 2010 | 9:46 PM
gotstylez's Avatar
so just started today is that when i start it it runs like it has a big cam then idle sup to 1500 then it starts idleing like befor 1000 RPM or so.. AND on the way home a few mins ago it stalled out for no reason... any help?? i plan on taking the EGR off this weekend and trying to clean it.
