Ignition Conrol Module
Old May 11, 2009 | 8:04 AM
Mud_Truckin's Avatar
Default Ignition Conrol Module
Is it possible for a Ignition Control Module on a HEI dist. to go bad, and be able to allow there to be spark?
Old May 11, 2009 | 4:49 PM
suzuki-guy's Avatar
you can tell by letting your truck run and tapping on the module if it sputters or shuts off its bad but usually when they go bad they just go bad
Old May 11, 2009 | 7:59 PM
Well at this point it just does not run??? It has spark, but the spark is yellow, and it is getting fuel, the only time it considers firing is while it is turning over with my foot to the floor????? Fuel is going to the carb, and there is spark.....
Old May 11, 2009 | 8:07 PM
suzuki-guy's Avatar
Sounds like fuel pump there may be fuel at carb but sounds like you dont have pressure. Hard to tell though. did it just go bad or did you mess with something? Let me know
Old May 11, 2009 | 8:08 PM
Mike Sigmond's Avatar
ROTM Coordinator
You can test the coils with a meter in ohms, gimme a minute I will look at my manual and post the resistance it should be at, you can do the same with fuel injectors.
aaahh, my manual does not have the coil test, I will check elseware.
Maybe this will help---- http://autorepair.about.com/od/troub...l-test-ohm.htm
Old May 11, 2009 | 8:55 PM
suzuki-guy's Avatar
he doesent have fuel injectors its caurbeurated
Old May 11, 2009 | 8:56 PM
ROTM Coordinator
I noticed that, I just figured Id mention it for people who do
suzuki-guy's Avatar
What condition is the carb in? If its still got the stock quadrajet in it those are junk i used a edelbrock on my 85
Old May 11, 2009 | 9:03 PM
Edelbrock 600.... It ran great and I parked it, the next day I went out and tried to start it and there was nothing, unless I hold the pedal to the floor it acts like it wants to start, otherwise, with my foot off the pedal, it just turns over like there is no spark????????????? This bastard is pissing me off, it has been a couple weeks, and I am giving it about -7 days until I rip the top half off and go to TPI, so if you know anyone looking for a VICTOR JR. high rise gap2 intake and a performer carb let me know, I climb too much crap and am always stalling.... and now after no changes it does not even run.... EFI here I come
Old May 11, 2009 | 9:06 PM
suzuki-guy's Avatar
is it flooded? floats could be stuck How old is the Carb? I would try rebuilding it cheap and easy if you follow directions!
