Ignition Lock Cylinder
Old Sep 23, 2021 | 8:21 AM
Ryan0811's Avatar
Default Ignition Lock Cylinder
The ignition switch in my Chevy Silverado 1500 LT recently started acting up. I purchased a new one after watching countless videos on how "easy" it is to replace. I followed the directions step by step and now I am stuck! The lock cylinder slot is sitting horizontally while the lock cylinder itself goes in vertically (with a slight. angle). When trying to reinsert the cylinder it essentially makes a tee with the slot and I'm not sure what to do next?
Old Sep 24, 2021 | 11:32 AM
Gumby22's Avatar
Pictures would be helpful, but it sounds like the new cylinder isn’t correctly indexed to the housing.
It’s been a while since I’ve replaced one but if I’m not mistaken the ignition switch (the part that the lock cylinder turns) has to be in the ON/RUN position and the key has to be inserted into the new lock cylinder to be able to line it up correctly.
frosome
Dec 12, 2014 7:15 PM
Arborist1212
Jan 12, 2013 8:39 AM
francis67
Nov 14, 2007 1:21 AM
dalkins1
Feb 6, 2007 9:54 AM
ptrkptz
Jan 23, 2007 3:43 PM
