Ignition module
My 1990 Silverado 4x4 has gone through 3 ignition modules in the last 3 months. The last one only lasted 8 days! I'm putting a liberal coating of dielectric grease on the back side as per instructions. I'm baffled, any advice would be appreciated. Thanks.
Turned out to be the pick-up coil. I'm not 100% sure though... a new pick-up coil got the truck started but the old one tested out to be fine.(???) I didn't change the module this time so maybe it was the p/u coil...I still don't have a good feeling about this.
You might have to get a little more aggressive than tightening a few connections.
Electricity moves on the outside of the wires. Corroded wires provide high resistance to a 12Volt system.
Consider replacing the cables.
94burb
Aug 2, 2009 8:06 PM
mikeski
Feb 16, 2006 9:41 PM
