IGNITION SWITCH PROBLEM-HELP
I HAVE A 1997 SILVERADO. WHEN THE KEY IS IN THE OFF POSITION THE TRUCK STILL HAS POWER. WHEN I ROTATE THE KEY TO ACCESSORY THE POWER GOES OFF. I REMOVED THE IGNITION SWITCH AND TURNED IT MANUALLY. ALL WORKS. IT APPEARS THAT THE GEARS FROM THE KEYSWITCH TO THE IGNITION SWITCH ARE OUT OF SYNC. ANY IDEAS ON HOW TO FIX THIS. I DON'T WANT TO FORCE THE GEARS AND POSSIBLY STRIP THE TEETH. ANY HELP WOULD BE APPRECIATED. THANKS IN ADVANCE...
bhwana
January 11th, 2015 1:28 PM
cd1965
November 18th, 2013 7:47 AM
gregory305
October 18th, 2012 1:27 PM
anryu451
February 12th, 2012 4:21 PM
