IGNITION SWITCH PROBLEM-HELP
Old Apr 13, 2008 | 5:23 PM
koverbey's Avatar
Default IGNITION SWITCH PROBLEM-HELP
I HAVE A 1997 SILVERADO. WHEN THE KEY IS IN THE OFF POSITION THE TRUCK STILL HAS POWER. WHEN I ROTATE THE KEY TO ACCESSORY THE POWER GOES OFF. I REMOVED THE IGNITION SWITCH AND TURNED IT MANUALLY. ALL WORKS. IT APPEARS THAT THE GEARS FROM THE KEYSWITCH TO THE IGNITION SWITCH ARE OUT OF SYNC. ANY IDEAS ON HOW TO FIX THIS. I DON'T WANT TO FORCE THE GEARS AND POSSIBLY STRIP THE TEETH. ANY HELP WOULD BE APPRECIATED. THANKS IN ADVANCE...
bhwana
Jan 11, 2015 1:28 PM
cd1965
Nov 18, 2013 7:47 AM
gregory305
Oct 18, 2012 1:27 PM
usmcpeacock
May 17, 2012 2:29 AM
anryu451
Feb 12, 2012 4:21 PM
