Inside bell keeps dinging while driving
Old Feb 11, 2012 | 9:52 AM
Doug Wells 69's Avatar
Default Inside bell keeps dinging while driving
When I put my 1999 Silverado in drive and start driving the inside bell starts dinging. I will stop when I stop at a stop sign or red light. When I start driving it starts dinging. Anybody have any ideas? If not does anybody know where the bell is located?
Old Feb 11, 2012 | 10:33 AM
skeeter5's Avatar
Doug,
This bell may be connected to the seat belts. I don't know how to disable it. You may
want to check all of your seat belt sensors.
This may be a start.
Good luck,
Old Feb 11, 2012 | 10:40 AM
Originally Posted by skeeter5
Doug,
Good luck,
Ill check it. Thanks.
Old Feb 12, 2012 | 10:27 PM
basilkies's Avatar
If you put something on the passenger seat it could activate the alarm if the belt isn't fastened. The seats have a switch that slides as the it is stretched from weight on the seat and turns the alarm on. Also it could be the switch is stuck on. The simpliest thing to try is fasten the belt on the passenger side and see if you still have a problem.
Old Feb 13, 2012 | 6:00 AM
Thanks basilkies. Ill give it a try.
Old Feb 13, 2012 | 11:37 AM
slw210's Avatar
It could be related to the brakes, or more acurately the sensor on the parking brake. I have bought 3 of them.
Old Feb 18, 2012 | 6:43 AM
It ended up being the parking brake. I pulled on the release lever and the pedel didn't move. I lifted up on the pedel and it shut the bell off. Thanks to all that offered help.
Old Jun 1, 2018 | 2:38 PM
Paul Gunderson's Avatar
Yes! Thank you! I have a 2003 Silverado and that dang dinging was making me crazy! I thought it was the door close sensor (like it thought the door was open while driving), but I tore my door apart and couldn't find anything. I found something on YouTube talking about clipping the light green wire at the A1 position in the light blue C4 sensor under the dashboard and that didn't work (all that does is stop the dinging when the door is open and the key is on). So I googled and found this thread. I never would thought it was the stupid parking brake! Thanks again. I can have my sanity back!
Old Sep 20, 2018 | 7:24 AM
mrwrightsmrs's Avatar
Default Finally, relief!
I have been about to lose my ever loving mind for 3 weeks listening to constant dinging. I even stopped by Meineke & asked them to reset my codes thinking is had to do with a faulty ABS light that’s been on for years. I finally google & come upon this as my first thread. I pull the break release & my sanity was instantly restored! Next time I won’t be so dense as to wait 3 weeks before checking online! 🤪😁🙌🏼
Old Mar 19, 2019 | 11:44 AM
Scotty Chaisson's Avatar
Default Thank you, thank you, stupid parking brake!
Thank you guys so much! I was like Mr. Gunderson, tried everything and IT WAS THE PARKING BRAKE! DAMN! IT! HA HA. thanks again guys
