Last edit by: IB Advertising
- Chevrolet Silverado GMT800, GMT900, and K2XX Why is Instrument Cluster Broken
Guide to diagnose trouble and recommended solutions.
instrument cluster problem
I have an 01 Silverado 5.3l with about 60k on it. Came across a problem the other day with my instrument cluster. When I start the vehicle, the lights that display my gear selection dont light up and my battery light comes on in the display. I also noticed that my engine temp sensor isnt reading. Everything else works fine with the dash and lights on my truck. When i put the key in and turn it once, the gear selection lights up and everything seems fine its only when i turn it again and start. I checked the fuses and none seem to be blown. Any idea as to what this may be?[/align]
[/align]
[/align]
I'm kind of interested in any feedback on this topic. My instrument cluster started having intermittent problems, then finally quit working all together. In trying to track down the problem, I noticed that I had a poor battery ground and tightening the connection seemed to make a difference.
Out of curiosity, does your panel go through the normal key-on sequence with indications for things like air bags and emergency brake and so on? Mine used to do that, but doesn't any more. I'm not sure what that means, but I'm reasonably sure it's not a good sign.
Thanks!
Thanks!
I have a 2000 Silverado and my battery light just started coming on and the gear selector isn't there. The fuel gauge was inop once for a few minutes then it started working. My problem is intermittent though.
I took it to the local dealer yesterday and they are telling me that it is the cluster that needs replaced. It's a little expensive..but it has to be done.
Last edited by hooch95; Jun 29, 2010 at 9:44 AM. Reason: took to dealer..told what was found
This happened to my truck not too long ago. Fuel gauge started working intermittently for a while, and then the cluster turned off and then reset if you hit a bump driving down the road. All in all, the cluster in my truck had to be replaced. Hope it helps!
Clusters on these trucks are pieces of S***. I had to replace mine after the trip button and gauge motor went out. You can eBay a new one, or buy direct from dealer. Dealer is WAY expensive. I bought mine off of a friend who owns a shop, the only problem is the only people who can program the mileage are the dealerships. 40$ and theyll program it.
Hey guys, sounds like there's several problem being brought up here, I'll try to help best I can.
On the 99-02 trucks the odometer/PRND123 display will go out intermittently and come back on if you hit a bump or bang on it with your hand - this is caused by a poor solder connection where the plug is soldered to the circuit board and it can be repaired. See here for a guide on how to do it - Silverado odometer problems
The fuel gauge problem on that generation of truck us normally caused by a bad fuel sending unit on the fuel pump assembly in the tank, requires replacement.
On the 03-06 trucks the gauge problems are typically caused by bad gauge motors which can also be fixed, here's some info on how to fix them yourself - Silverado instrument cluster problems
That generation of truck also has fuel sending unit failure a lot which will cause the fuel gauge to read wrong, requires replacement.
The 03-06 trucks have another issue where the entire instrument cluster will quit all at once and sometimes come back on/off/on, chimes ringing, lights flashing,etc. This can be caused by a faulty ignition switch, requires switch replacement.
And finally, on the 03-06 trucks if you notice the 4 gauges on the right quit suddenly all at once along with lights coming/staying on it's a failing IC chip on the circuit board - cluster replacement required.
Hope that sheds some light and can help some of ya.
Fred
www.DrSpeedometer.com
Oh ya, one more I see a lot - if your oil pressure gauge is bouncing from 0psi to 80psi don't panic, it's not your motor or your gauge whacking out. It's a poor electrical connection around the oil pressure sensor/switch causing it to read full pressure then 0 pressure.
Fred
i know for the 03-06 trucks chevy sent out a warranty for bad stepper motors inside the cluster. since it is a safety issue it was free to get it replaced from the dealer. im not sure if they sent out a warranty for the 99-02 trucks.
