intermitten squelling sound
Old Nov 22, 2010 | 12:25 PM
lmks6666's Avatar
Question intermitten squelling sound
1999 1500 silverado 4x4. when driving with the fan on i get an intermitten squelling like a belt slipping. it only happens over 1500 rpm. if i drive under 1500 rpm it does not make noise and if i turn the fan control off while driving over 1500 rpm it stops. any idea's?
truck has 130000 mi on it.
Old Nov 22, 2010 | 11:51 PM
OLD WRENCH's Avatar
Default squeal
Are you running the defroster? This would automaticly turn the AC on putting more load on the belt.
Old Mar 21, 2019 | 6:07 PM
Garry Allen Smith's Avatar
Default Squeal
  • sounds like it may be the water pump bearings
Old Mar 22, 2019 | 7:51 AM
How old is the serpentine belt? Check the belt and the idler and tensioner. It sounds like the belt might have stretched some and starting to slip at times which will get worse as time goes by.
jim2706
Jan 10, 2012 3:31 AM
stdhawaii60
Dec 24, 2010 11:14 AM
kccos
Sep 2, 2009 6:50 AM
jlbeir
Nov 21, 2008 4:11 PM
Laketruck
Mar 19, 2008 4:48 PM
