intermittent abs brake issue
Old September 26th, 2006 | 11:50 PM
its.all.hers.chevy's Avatar
Default intermittent abs brake issue
I am having a problem with my 02 chevy 2500 hd abs brakes. when I go to brake, the brake pedal pulsates. It does not matter if I am on a dirt road or pavement, doesn't matter what the weather is (could be sunny!) and I don't have to be going fast like you normally would to feel the abs brakes to come on when you slam on them. And it doesn't happen every single time. There is no abs light on at all. Had the mechanic look at it and drive it...can't find anything wrong with it.
Old March 25th, 2007 | 4:20 PM
CdnFD24's Avatar
Default RE: intermittent abs brake issue
I am having the same issue with my 2001 Chevorlet Silverado 1500 extended cab 4x4. 5.3 V8 Vortec.
I've had the low speed sensor replaced with a new one and had new tires put on. This did not fix the problem.
Old March 26th, 2007 | 6:02 PM
outcol483's Avatar
im having same problem also, I have the same truck as you CdnFD24, 2001 chevy silverado 1500 ext cab 4x4 5.3 v8 vortec, it does it maybe 5 - 6 % of braking time. on dry roads
Old April 2nd, 2007 | 3:09 PM
sm3earl's Avatar
Maybe a vacume problem going to the brake booster?
Old April 2nd, 2007 | 8:50 PM
golfer's Avatar
When you feel the brake pedal pulse ... do you hear the ABS actuator engage ?
Old October 30th, 2007 | 1:06 AM
bluechevy's Avatar
I have the same issue with my '01 Silverado 5.3liter 4x4. The ABS motor cycles 80% of stops but no light is on in the dash.
Old October 30th, 2007 | 10:19 AM
golfer's Avatar
ORIGINAL: bluechevy
The only time the ABS light would be on if there were a problem with the sensor circuit or the ABS motor/pump system.
Having the ABS come on is not that uncommon. It can be caused by wrong tire inflation , wrong size tires , wheel hop while braking , sloppy wheel bearings , dirty or broken teeth on the reference ring , loose sensor pickup , etc.
Old October 31st, 2007 | 7:28 AM
03chevyrustbucket's Avatar
Go to www.car.com, there you will find a re-call for that problem. The dealers will make the repairs. I think at no cost to you. This re-call was back in 2005, campaign # 05v379000, You can call chevrolet at 1-800-630-2434 for more info.
I hope this helps all of you
Old October 22nd, 2014 | 10:18 AM
burb01's Avatar
Default Same old abs pulsing issue.
On my 01 Suburban my brake petal pulses sometimes when braking making as loud noise and wont stop unless I pump the brake once or twice. The comments here are old. So what is the fix? I have spent tons of $ trying to get this fixed.
Help !
tyafrya
May 15th, 2015 6:14 PM
cmcbride
Avalanche
August 8th, 2012 4:12 PM
Thad W. Posey
June 15th, 2012 10:21 AM
primesuspect
October 13th, 2011 10:53 PM
mkmaha
June 12th, 2008 3:25 PM
