Intermittent Squealing Sound From Engine
Old Dec 2, 2015 | 11:51 AM
Larrycarol's Avatar
Question Intermittent Squealing Sound From Engine
Lately, I've been hearing an intermittent squealing sound on my 2003 Silverado 1500. When it starts, if I increase my speed slightly it stops for awhile. I'm thinking either water pump or fan. How can I tell if it is either of them?
Old Dec 2, 2015 | 10:24 PM
Rednucleus's Avatar
I vote for the belt as the noise source. When was last change? What's your mileage?
Old Dec 5, 2015 | 10:24 AM
cleveland63b's Avatar
check both your belts for cracking, if they look ok remove them and spin the pulleys listening for noise
Old Dec 5, 2015 | 1:55 PM
Cowboycoupe's Avatar
Belts. One way to check would be to spray the belts with a belt conditioner aerosol. If the noise goes away, it's a loose or hardened belt. I've heard of guys just rubbing a soap bar on the belt as it spins, but that sounds real risky if you get your arm caught in the belt or fan, so I cannot recommend that you do that.
