It's cold (new member)
Old Jan 25, 2009 | 11:51 AM
KSRider's Avatar
Default It's cold (new member)
I have a 1999 Silverado blowing only cold air, fan works great, mode works, it changes zones, but no heat and its 8 degrees outside. Any clues? Thanks
Old Jan 25, 2009 | 2:09 PM
You may need to get down at the lower vents and verify that the blending door is opening/working. Probably whats happening is the heat is there at the heater core but is not being allowed to enter the vehicle becasue the door is not opening because its stuck or is not working anymore.
Old Jan 25, 2009 | 6:48 PM
shawnvw's Avatar
Banned
make sure the rad has coolant in it as well....no antifreeze = no heat
Old Jan 25, 2009 | 10:18 PM
KSRider's Avatar
Ok, further info: the radiator is full, I haven't checked the door but I did check the heater hoses, one is warm and the other is cold. If the door doesn't open will the water still circulate through the heater core?
Old Jan 25, 2009 | 10:19 PM
Gwampa's Avatar
And then there's the old thermostat ploy too...............
Old Jan 25, 2009 | 11:16 PM
shawnvw's Avatar
Banned
If one hose is warm while the other is cold, your heater core is likely plugged....either flush it or replace it
Old Jan 28, 2009 | 9:12 PM
KSRider's Avatar
I had the heater core flushed and it fixed it. Thanks guys
bub2000sierra
May 30, 2012 10:15 PM
mdec950
May 11, 2012 9:44 PM
Supertwins
Jul 4, 2011 11:39 AM
Mille Racer 69
17
Nov 7, 2010 4:19 PM
Donzi4me
Apr 22, 2007 3:33 AM
