James
Old September 13th, 2012 | 6:28 AM
James1969's Avatar
Default James
I have a 2010 Z-71 with 33x12.5x20s and my gas mileage is crap. If I have the truck programmed will this give me an increase in gas mileage or do I need to change the gear ratio?
Old September 13th, 2012 | 10:34 AM
country_09's Avatar
6 speed or 4 speed tranny? A custom tune will do wonders for it. 33s aren't as big a difference as 35s so regearing may not need to happen. What gears are stock in the truck and what motor?
Old September 13th, 2012 | 8:34 PM
James1969's Avatar
5.3 with 6 speed trans. Not sure about what the gears are. I think they are 343 but not sure.
Old September 13th, 2012 | 9:00 PM
country_09's Avatar
Airaid intake tube and filter then Custom tune and be done. Should net 2-3 more mpg. What are you gettin for mpg's right now?
Old September 13th, 2012 | 9:34 PM
James1969's Avatar
Right now I am getting 13-14 on the highway.
Old September 13th, 2012 | 10:07 PM
country_09's Avatar
That's not that bad. Do the intake tube and filter then get a custom tune. Should put you around the 15 mpg mark and make the truck much more fun to drive
Old September 13th, 2012 | 10:30 PM
James1969's Avatar
Good deal. Thanks for the info. I am going to get this done soon as I get home. I am also going to install true dual exhaust system with 12" glass packs. So it will sound pretty sweet as well.
Old September 14th, 2012 | 8:15 AM
country_09's Avatar
If you dual it out you'll lose some bottom end torque and don't go to big of a pipe. No larger than 2.5" on a stock motor, get them to install a x-pipe in it as well
jamespsj
April 15th, 2015 10:15 PM
Quick Reply: James
