Keep blowing rear seals
I have my 03 and i keep blowing rear axel seals like with in 3000 miles or less is there anything i can do to fix this??
If the vent tube is clogged or the rearend is over filled it will blow out your seals. Another thing it could be is the bearings are bad causing excessive play. Worst case a bent axle or axle tube.
Tkarcher
October 18th, 2015 11:25 PM
