Keep blowing rear seals
Old Jun 20, 2010 | 8:52 PM
sledneck421's Avatar
Default Keep blowing rear seals
I have my 03 and i keep blowing rear axel seals like with in 3000 miles or less is there anything i can do to fix this??
Old Jun 21, 2010 | 11:50 AM
cooter26's Avatar
If the vent tube is clogged or the rearend is over filled it will blow out your seals. Another thing it could be is the bearings are bad causing excessive play. Worst case a bent axle or axle tube.
Old Jun 21, 2010 | 6:56 PM
Ya i have changed all the bearings i need to check the vent tube thanks
Old Jun 21, 2010 | 8:24 PM
MDTAHOE's Avatar
Professional Mechanic
Check the axles for scoring, if there is any than you need new ones.
Tkarcher
Nov 2, 2024 10:09 PM
raydar
Jan 20, 2023 10:46 PM
Tracker Trailblazer
Jun 26, 2015 6:03 AM
txmusic
Apr 26, 2010 11:47 AM
My_Hoe
Oct 18, 2008 2:44 PM
