knock sensor 6.0L
Old Mar 7, 2013 | 9:09 PM
ekimw2500hd's Avatar
Default knock sensor 6.0L
anyone have to replace these? how long did it take and how hard was it.
Old Mar 7, 2013 | 9:23 PM
country_09's Avatar
Pull the intake manifold and they sit right on top of the block. Takes a few hours but it's not hard at all
Old Mar 7, 2013 | 9:30 PM
f5fstop's Avatar
What year vehicle? I believe 800 has sensors located as described above. GMT900 had sensors noted below.
Do you have codes to determine which sensor; 1 or 2?
DTC P0325, DTC P0327, DTC P0328 relates to sensor 1
DTC P0330, DTC P0332, DTC P0333 relates to sensor 2.
Sensor 1 is located on the lower left of the engine, sensor 2 is on the lower right. Not sure if manifold has to be removed; from memory I believe you can access them from under the vehicle since they are located toward the bottom of the engine.
Might have a picture...
jdog
Dec 10, 2024 12:11 AM
jffgin
Mar 10, 2008 2:32 PM
desilverado
Mar 24, 2007 4:10 AM
jamesdal7
Jul 18, 2006 11:11 PM
