led lights.
Old Jan 19, 2010 | 6:24 PM
s34n's Avatar
Default led lights.
i installed a pair of led bulbs(3157) into my turn signal bulbs on my 04 silverado flicked on the turn signal lever. and my bulbs work but flash really fast instead of normal speed. any suggestions as to what to do?
Old Jan 19, 2010 | 7:43 PM
you probably need a load resistor in place, the LED's do not create enough resistance for the circuit to work correctly, the system thinks the bulb is out so it flashes quickly...
Old Jan 19, 2010 | 9:16 PM
s34n's Avatar
thanks for the help. thats what i was looking at. not sure if i want to do it tho.
Old Jan 20, 2010 | 7:24 AM
You might check with mdtahoe, I think he may have upgraded to LED's on his Tahoe and he may be able give you some input as to where he got them and which ones worked...
Old Jan 20, 2010 | 1:01 PM
cams 98 silverado's Avatar
they sell the flasher that has the resistor in it already. so you just plug in a new flasher. or get bulbs with the resistor in the bulb already.
Old Jan 20, 2010 | 2:13 PM
s34n's Avatar
thanks everyone for your replies. i will look into this.
Old Jan 27, 2010 | 9:31 PM
abram's Avatar
I did it on my 01 duramax, just changed the flasher, which is in a hell of a spot to get to under the dash, but mine woek great, no problems at all!!
Al
Old Jan 28, 2010 | 8:55 AM
bwaterfowler15's Avatar
What kinda bulbs would be a good one to use? I've been wanting to upgrade to these on my z71.
Old Jan 29, 2010 | 9:44 AM
PelletMonster's Avatar
Where did you get the flasher? i changed all tail lights and front markers lights over flashes fast here and there, would like to fix the problem.. thanks
Old Jan 29, 2010 | 6:33 PM
s34n's Avatar
i bought the light off a website called autolumination.com
TPeezy
Oct 3, 2008 2:33 PM
lsharrin
Aug 11, 2007 6:14 PM
07hoeon26
May 28, 2007 9:19 PM
mcconcma
Sep 22, 2006 3:19 AM
