Long cold crank before start
Old Dec 14, 2019 | 7:28 PM
Matthewe's Avatar
Default Long cold crank before start
Is there a common problem on a 1995 which requires extended cranking before start up? My first assumption is fuel bleeding back to tank because ruptured fuel pressure regulator because of ethanol fuel.
Old Dec 14, 2019 | 8:18 PM
a check valve in the fuel pump stops the fuel from bleeding back to the tank. unless you re running e85...ethanol shouldn't be a problem 10% ch3ch20h is just fine.
skram
Mar 23, 2019 9:35 AM
Wexe49
Dec 30, 2014 1:15 PM
ToooTall1
Feb 2, 2013 10:39 PM
Garon
Nov 21, 2011 8:18 PM
Sparky Sparks
Mar 9, 2011 9:11 AM
