Loud Humming Noise In Front End
Hey guys,
I have a 2003 chev 1500 4x4 and lately i have been getting a really loud humming noise coming from the front end. It starts to make noise from 40 Kph all the way up and the loudest point at about 110 Kph but never really goes away. The only time it will stop is on LH and RH curves at highway speed and it will momentarily stop as i hit dips in the road. it seems to be the worst coming from the LH side front (Drivers Side). I have jacked up the front end and the wheel bearings dont have any play in them( Hands at 12 and 6 then proceeded to rock the wheel and no play at all) and the wheels have been aligned that didnt help. No worn parts as far as i can see so now i am stumped.
Any Ideas?
Thanks guys
Any Ideas?
Thanks guys
Rule is, if the noise can be changed by "rocking" the truck and thereby shifting the load, it is coming from a wheel bearing.
If not, noise is orginating somewhere 'inboard' of the wheel bearings.
Allan
Alright that does make sense!
So now with these sealed hub bearings would you still see the play in them like the old cup and bearing set ups when they are out the door? or are we past that kind of check now
Thanks alot guys very helpful!
There's no possible human error in torquing the wheel bearings and thus I don't believe you can actually feel the play with these bearing/hub assemblies. What you may be able to feel is uneven rotation or rough spots while rotating the wheel by hand with the front off the ground. Mind, wheel bearing noises can appear to come from a wrong location (side to side, front to back). Let someone else drive it while you sit in the back and listen.
ClintM
Sonic (Aveo)
Jun 20, 2011 11:51 AM
