low oil pressure
Old Jan 14, 2011 | 11:40 PM
dspla001's Avatar
Default low oil pressure
Hey guys, my wifes 05 trucks oil gauge keeps going from 0-max (80? i think), there is the right amount of oil in the truck and it seems to run fine, when its says 0 and i turn the truck off, the gauge will reset and work like it normally should. is this a sensor problem or a pump problem? thanks.
Old Jan 15, 2011 | 1:46 AM
2wd-K5's Avatar
hmmm good one, it may be a sensor why not get a mechanic to hook up a mechanical one quickly to see if the guage is right or if it is wrong....but at the price of a mechanic doing this u could just buy the sensor
Old Jan 15, 2011 | 7:13 AM
dspla001's Avatar
yeah im trying to avoid that, my question is, if the pump is faulty wouldnt the engine be running noticeably different? also if its the pump/sensor wouldnt the check engine light come on so i could read the code?
Old Jan 15, 2011 | 8:36 AM
country_09's Avatar
my 01 was doin the same so I replace the sensor and it works great now. no fluctuatin at all...but mine didn't throw a code so the light never came one
Old Jan 15, 2011 | 9:59 AM
dspla001's Avatar
ok cool, is that a pretty quick straightforward job or a PITA?
Old Jan 15, 2011 | 12:27 PM
country_09's Avatar
straight forward lol. oil pressing sendin unit is what I replaced. bought it at autozone and had to get the special socket for it too but you just unscrew the unit and screw the new one on. the hardest part is gettin to it, its on the back of the motor on the drivers side so you'll have to feel around for it but it sticks straight up
Old Jan 15, 2011 | 12:53 PM
dspla001's Avatar
yeah i figured it couldnt be to complicated, i just want to make sure that is the problem before i spend money/time replacing it
usernamehere
Aug 2, 2021 12:07 PM
Eric Sherden
Sep 24, 2013 1:21 PM
not_a_car_dude
Sep 15, 2013 7:41 PM
MikeShirk
Dec 31, 2012 10:39 AM
larry_chip
Apr 24, 2007 11:46 AM
