Low operating Temp.
I have a 1991 Silverado with a 305 ci. engine and I can't get it over 150 degrees. I changed the thermostat 2 times and tried removing the fan.I also blocked off the radiator, all did not help. I by passed the heater thinking that might be doing it, but no good.My gauge is correct because I also put a test thermometer in the Rad. and both read the same. Any help will be appreciated.
I had a 90 that was like that and nothing had any affect on it. I replaced the lower heater hose and the troublesome connector that scews into the intake with a hose barb and it works great. Dont ask me to explain it.
I have replaced the heater core. I bought a Stant thermostat. I flushed the system twice. I replaced both sensors. The coolant itself is just not hot. I believe the gauges are telling the truth. The heat is warm, at best. This all started when I replaced the intake manifold gasket. I have a friend who's truck did the exact same thing when he did the same job. There was an extra little pin hope in the new gasket and we think that's allowing enough coolant through to keep it cooler
proballer25
Apr 29, 2010 11:21 AM
Escort-Performance
Aug 13, 2009 8:34 AM
