Lug Nut Trouble
Old Oct 11, 2011 | 10:14 PM
Leroy.Hass's Avatar
Default Lug Nut Trouble
So I just got this truck a few weeks ago, and at first I thought one lug nut on each wheel was a locking nut because it sunk into the rim, and the tire iron will not fit in there to grip it.
There is no special tool in the truck, and I can't get the nuts out. I've bought replacements, but I need to get the old ones out first. The trouble is that I'm certain these are aftermarket rims, so GM probably won't have anything to help, and I can't find anything about this online.
Any ideas?
Old Oct 11, 2011 | 10:21 PM
OLD WRENCH's Avatar
A picture would be a lot of help. I have ran into deals like this before. Air chisel,grinder,drill.
Old Oct 11, 2011 | 10:48 PM
Leroy.Hass's Avatar
http://i1106.photobucket.com/albums/...oyHass/007.jpg
http://i1106.photobucket.com/albums/...oyHass/003.jpg
Old Oct 12, 2011 | 12:05 AM
Leroy.Hass's Avatar
A friend of mine came over after work and checked them out. He believes it's a special nut that requires an attachment to remove it (locking nut of sorts). I'm not sure if this is correct, though, because there's no key slot on the top like you would usually see.
Old Oct 12, 2011 | 9:19 PM
OLD WRENCH's Avatar
Have you tried a regular socket on them?
Old Oct 18, 2011 | 2:06 AM
Leroy.Hass's Avatar
That was the trick! The tire iron was too thick to fit inside the hole. Turns out 5 of the lug nuts are 19mm, and the 6th is 21mm. I tried a deepwell socket with a breaker bar and it worked like a charm. Thank god I didn't get impatient and slice up the nuts!
H07
Apr 26, 2025 3:34 PM
jen2swt
May 29, 2010 8:45 AM
jusina
Feb 13, 2010 8:29 AM
sixpack_sid
Jul 30, 2009 8:56 PM
jcw1500wt
Jun 30, 2008 3:33 PM
