Mis at idle and code P0300
Old Mar 9, 2011 | 1:44 PM
98coppermetallic's Avatar
Default Mis at idle and code P0300
I have a 98 K1500 5.7 vortec. I just purchased a jasper re-manufactured engine in January and with the engine I put new plus, wires, cap, rotor, cam sensor, tps, crank sensor, fuel filter, air filter and gear on dist bottom and the truck has been good. I now am getting a rough idle and a P0300 code. I had my mechanic run diagnostics on the truck. He said my timing is off when it idles. When you give it a little gas it corrects the timing. He's thinking I may need a new distrib or a ECM. He has a good used dist he wants to put on and try and if not he was thinking ECM. I was wondering if that sounds correct to you guys. I was thinking my fuel pump was lose pressure but didn't know if it would cause the time to be off. Any help would be great.
Old Mar 9, 2011 | 7:08 PM
RacerX's Avatar
why doesnt he just move the distributor to fix the timing retard? you cant set timing at idle, you have to be a like 800rpms in neutral. Loosen the hold down bolt and move the distributor back and forth slowly to hear the perfect tune if you dont have a timing light. You should be at -10BTDC I believe for this motor. Someone will confirm this.
Eose
Feb 19, 2014 10:35 AM
Miketheoldone
Nov 26, 2010 11:48 PM
UnRumble
Dec 20, 2006 8:57 PM
MWRacing
Sep 27, 2006 7:29 PM
