missfire cyl 1+6
i have an 05 silverado with 120000 keeps coming up with missfire cyl 1+6 replaced coils plugs wires did compression check checked valve springs nothing seems to be wrong also moved around injectors still the same cylinders looking for advice
Thats funny, last summer i had a chevy firetruck come in with the same codes. i did the same as you until my boss told me to replace the fuel regulator valve. ran like a new motor after that! that valve cures alot of issues. id also check the fuel pump and pressure before you replace the valve, but im confident you might have a regulator going out
![Smile](https://chevroletforum.com/forum/images/smilies/smile.gif)
philgethifi
16
May 27th, 2009 11:52 PM
