motor decoding help.
Old Oct 18, 2011 | 6:11 PM
81scottsdale's Avatar
Default motor decoding help.
i have a 81 scottsdale. that i thought had a 305. but when i pulled the motor i seen on the block the numbers said 25 GM 3970010. i was wondering if someone could tell me what it is. thanks.
Old Oct 18, 2011 | 6:41 PM
maxxman04's Avatar
http://www.strokerengine.com/SBCcasting.html
scroll down and you will see this decodes as a 2 or 4 bolt main 350 block, '69-'80.
Old Oct 19, 2011 | 4:19 AM
Ok. Why couldn't it be a 327? Has the same number.
Old Oct 19, 2011 | 6:05 PM
maxxman04's Avatar
MOST, not all, production small blocks use the same block, just different cylinder bore sizes, crank journals basically. a measurement of cylinder bore diameter can tell alot.
hotrod_tim
Camaro
Jun 26, 2014 8:32 PM
twinkey362
Aug 24, 2012 5:43 AM
wayneeworkman
Nova & Chevy II
Dec 5, 2008 2:31 PM
jobberone
Nov 16, 2006 10:13 PM
