My OBD2 port will not work
Hi. I have a 2007 Silverado and my check engine light came on. My scanner won't link but it works for all of my other vehicles. A google search suggested that the cigar lighter fuse being blown can cause this but my truck doesn't have the smoking package and I can't find that fuse. The scanner acts the same whether I have the ignition on or not. Any ideas would be appreciated.
Thanks from Mike in NH.
I had a similar issue with my 2011 model. It does not have a cigarette lighter, but does have two 12V ports on the dash. If I use one of the ports I can almost garuntee that I blow the fuse for that port. For some reason Chevy decided to wire the OBD II port to this same fuse. I would double check the fuses. Check and see if you have a CIG LTR fuse the in engine fuse block and check to see if it is blown.
I have a 2005 Silverado 1500 with the cigg lighters and today my truck is showing abs and showing the light for bad alternator but had both tested and it shows they are good then went to test obd and wont connect to tester could I be having the same problem with the fuse?
so I am having an issue where my obd2 port does not connect to my scanner along with the battery light and abs light on the door controls don’t work like heated seats, lock an unlock, windows, speakers, and I let it sit and it won’t start. Really confused on this one but would really appreciate some help it’s a 2005 Silverado 2500 6.6. Also just changed out the block heater since it was bad then all of this happened. Also the fuel level guage and ect and tft guage don’t work. And the voltage guage is always around 10v but starts right up if sitting inside.
mgssuburban
13
February 17th, 2023 9:36 PM
