NEED BETTER BRAKES
Old Jul 23, 2008 | 8:21 PM
Poi Dog's Avatar
Default NEED BETTER BRAKES
I have an 89 K1500 with a 4" lift and 20" wheels and my braking ability sucks. The truck has the standard duty brakes and is all new. I can't find a big brake kitfor it. Anysuggestions??
Old Jul 23, 2008 | 9:04 PM
old dog's Avatar
Default RE: NEED BETTER BRAKES
try stylin concepts
Old Jul 24, 2008 | 5:45 PM
jkgray80's Avatar
Im all for upgrading brakes w/large tires but, are you sure it is the extra wheel/tire weight? Should be very hard pedal if so. Not soft, low, etc.
Old Jul 24, 2008 | 6:44 PM
old dog's Avatar
it can have a lot to do with increseing the roling resistance .
Old Jul 25, 2008 | 5:22 PM
Poi Dog's Avatar
Thanks for the replies! I'm looking into putting 1 ton calipers on it, along with a heavy 1/2 rear set up.
Old Jul 26, 2008 | 10:10 AM
itlldue's Avatar
The extra torque you put on the rotors/drums with the bigger "footprint" is comparable to putting a two foot cheater pipe on a rachet. The diameter of the rotor/drum should increase at the same rate as the tire/wheel size for the system to work properly. Even doing that, the brake mounting apparatus isn't engineered for the extra strain.
Of course, the manufacturers love it when you make those kind of changes. It keeps them out of the liability loop if there's ever a problem........
thetater96
Sep 17, 2014 11:11 AM
connell2449
Jun 3, 2011 10:07 AM
Mille Racer 69
Dec 8, 2010 8:26 PM
Lambo3244
Jan 18, 2009 8:55 AM
96 chev
Mar 19, 2008 11:54 AM
