Need help!
Need help!
Hey guys new here from Texas and I have a problem goin on with my truck! The gas gauge always reads empty even after pumping and I have no idea what it can be! Any of u had this problem or have any clue as what it can be? Thanks
Welcome to the forum. Does the gauge needle do the sweep during the bulb test, i.e., when you first turn the key on? When did the problem start? Was this an abrupt or gradual thing?
Yep sure have had this problems last time i had to mess with my fuel pump the float in there got stuck i just dropped the gas tank down again and worked that arm that the floats on a little bit and it was good also a wire coulda popped out of the harness inside hope this helps but dropping the gas tank or taking the bed off to check it kinda sucks. but it is much cheaper to do it yourself at least in idaho the shops wanted way too much
be_Martinezr
October 6th, 2014 10:19 AM
1stTahoe
April 19th, 2012 9:44 PM
upzaw2000
HHR
December 31st, 2006 9:36 PM
