Need help 98 Z71
Old Jun 9, 2010 | 11:24 AM
smilfs 98z71's Avatar
Default Need help 98 Z71
'98 Z71 sat up for year or so. Charged batt and fire right-up. Run like a champ for about two mins then cut-off. Won't start up now. Plugs are getting spark. Thing it's getting fuel, but have not pressure tested yet. Fuses all look good. Heard about low oil pressure hooked to starting. Don't know how to check that if engine won't start. Please Help
Old Jun 9, 2010 | 9:02 PM
MDTAHOE's Avatar
Professional Mechanic
You need to see actual fuel pressure. Even if you pulled the line and you see it pumping fuel it could still not have enough pressure. How does the gas smell? It maybe too old to burn. Check to make sure you have BLUE spark.
Old Jun 10, 2010 | 7:07 AM
MD,thanks for the info. I'll check pressure, spark, and change fuel this weekend. If all is good what would be the next step?
Old Jun 10, 2010 | 7:55 AM
vBruce's Avatar
Pull the codes and Im sure it tells what sensor is bad...
99ChevyZ71
14
Aug 29, 2012 8:22 AM
jgray152
Feb 19, 2012 11:12 AM
smilfs 98z71
Jun 7, 2010 8:40 AM
deejayrock
Sep 30, 2008 10:03 PM
live4perfection
May 6, 2008 10:59 AM
