need help asap mechanic question
Old Oct 16, 2012 | 2:07 PM
Sgt.Pintye's Avatar
Default need help asap mechanic question
Ok there is a black hose near the transfer case and its leaking oil or trans fluid, i think trans fluid, it became disconnected and i cant find were to hook it up too.
Old Oct 16, 2012 | 2:43 PM
kevinkpk's Avatar
How bad is the leak? It might be a vent line, is the transfer case overfull?
Old Oct 16, 2012 | 2:44 PM
CHEVYCRZY007's Avatar
Default Vent hose???
Is the hose that is leaking run up to the top of the transmission? If so then it is your vent hose. They normally leak for one or two reasons. The transmission is overheating or the tube itself is plugged up. Your transfer case will also have a vent tube, but should have a plastic cap on the end of it. Hope this is of some help to you.
Old Oct 16, 2012 | 5:57 PM
Sgt.Pintye's Avatar
it only leaks wen it faces down. i have it faceing up so it wont leak.
Old Oct 16, 2012 | 6:59 PM
GMcerttech's Avatar
its a vent hose im almost 100% sure gm usually uses metal lines for the trans and oil cooler lines and rubber hoses for the vent hoses and coolent hoses. fallow the hose back see where its coming from if it comes from the trans then its just a vent hose and your trans is over filled in which case you need to check the transfer case to see if its over filled as well. if it is then you need to replace the seal between the two.
Old Oct 16, 2012 | 7:19 PM
Allan In NE's Avatar
Transfer case vent hose. The plastic connector has broke.
And, it's not because anything is "overfilled", by the way.
Allan
Old Oct 16, 2012 | 7:23 PM
GMcerttech's Avatar
that would do it too
Sgt.Pintye's Avatar
Allan
soooo i hope ur right cus im not replacing any seal
lol
Old Oct 16, 2012 | 7:24 PM
Sgt.Pintye's Avatar
how do u fix that by the way?
montecarlo04
Jan 5, 2014 9:50 PM
CamaroFan107
Sep 28, 2010 7:07 AM
MissMonte04
Aug 17, 2010 8:14 PM
MAD King
Apr 3, 2010 7:54 PM
bert
Feb 12, 2007 2:25 PM
