NEED HELP guys
NEED HELP guys
alright so i recently had my transmission go bad in my 97 k1500 so i pulled it out and bought a rebuild kit and rubuilt it, well 2 days ago i out it in and after filling it, i went to start it and i got nothing, i just here the relay for my push button starter clicking, i have a good charge for my battery, also i had to replace the module that bolts to the driver side of the transmission, i had to replace a section of the pig tail and the module, well i traced part of the problem down to the fuse block, i noticed that the "engine 1" 20A fuse in the fuse block was blown, so i replaced it and as soon as i went to start it it got blown again, does anyone know what that fuse goes to?
You have a wire grounding out. Go back to your modified harness and tripple check everything. ant just for bare wired, but also check to be 100% shure u didnt hook a pos to a neg.
ha it actually wasnt a bad ground nor a bad connection, i went to the junk yard, and got another MLPS, which is the nuetral safety switch and wired it in yesterday and it ended up that it was the the switch itself that was faulty, now that i installed the new switch, she starts up perfect, thanks
89silverado283
28
July 9th, 2011 8:54 PM
