Needle pin bearings in oil "not rocker arm"
Old September 2nd, 2020 | 1:04 PM
  #11
gmc_guy's Avatar
I purchased the engine from JEGS. It was between $3k-$4k. I did the swap myself. Since I am a student and full time employee, it took a while to find the time, but it wasn't that hard to do. If i find pictures of the damaged bearings, I'll post them. It might help with the bearing count per lifter.
Old September 4th, 2020 | 8:21 AM
  #12
TexasSteve's Avatar
sharing more.. hope this helps others. I removed heads.. Rockers were intact so no pins from rockers. All lifters look good except 1 lifter on cylinder 1 (towards cab side) won’t come out. It does turn and will come out about 1 inch but stops. I am leaving it for now. Per pics I found some lifters showing pins so they do exist. Of 3 pics I found 2 of them have 17 pins and another 18 pins. I have found 16 in my oil pan. I have not opened my filter but think none can get in it due to the metal screen.
I am going to rebuild top of engine (it is needed) with all new Melling products. I also am replacing cam.
any advice on the stuck lifter? Maybe try to remove cam first ?
basicbob101
February 20th, 2017 1:34 PM
Tucson John68
Avalanche
July 10th, 2015 4:22 PM
The Chevro
February 1st, 2012 7:15 AM
dleatham
August 10th, 2007 6:50 PM
Quick Reply: Needle pin bearings in oil "not rocker arm"
