New guy here
#15
you guys are jumping around way to much, cover the basics first
Remove the fuel filter and blow through it, if you can easily its fine if not replace it if the pressure is still low you need a pump
Security systems won't give you low fuel pressure
#17
yes i got 60 psi but only after cycling the key several times. I do think its the pump like the other guys said. I didn't get much done on it yesterday but when the key was turned on i could hear the pump run but it didn't sound very good. So pump and filter first and i'll go from there. Thanks again
Spice Boy
January 27th, 2010 6:37 AM
