new tires and they rub
i put on my new tires and they rub my bumper. i am wondering if i should cut into the bumper about an inch or so or should i move the bumper up. if i move the bumper i have to make brackets and if i cut it, it will rust. which would be easier or are there any alternatives?
Last edited by in2pro; December 19th, 2012 at 7:20 AM. Reason: updated title from "help" to new tires rub
Trucks an 02 silverado 2500hd. I cranked my keys up about 5 turns and it sits leveled now. The tires are 285/75-16 width is 8.5. Tires rub the bumper and im thinking about extending the bumper out. I can provide pics if that helps
how difficult is it going to be to do blocks? can you direct me to a site that sells them? im searching now and keep coming up with full on 6in lifts.
Blocks are super easy. Just go to a junkyard and get some 1.25" blocks from a 07+ 1500 silverado and then get new u-bolts from a lift shop or have a parts store make you some
Would be the easiest way to go about it
Cut the black bumper moulding on the bumper bottom. On each end cut from top where it connect to bumper and cut towards the bottom of moulding on an angle of 1 to 2 inches towards the front. That will give you clearance for your tires. My 2001 2500hd with 285x75x16 have no problems with clearance after the mod. Send picture if you can
QUOTE]
Heres the pic. Il need to cut an inch or so. I dont thibk lifting it another inch will help
