new tires and they rub
Old Dec 16, 2012 | 5:38 PM
BigRed922's Avatar
Default new tires and they rub
i put on my new tires and they rub my bumper. i am wondering if i should cut into the bumper about an inch or so or should i move the bumper up. if i move the bumper i have to make brackets and if i cut it, it will rust. which would be easier or are there any alternatives?
Last edited by in2pro; Dec 19, 2012 at 7:20 AM. Reason: updated title from "help" to new tires rub
Old Dec 16, 2012 | 11:22 PM
if the truck has torsion bars you could turn up the keys. It will change the alignment angles so an alignment will be needed.
Old Dec 17, 2012 | 7:26 PM
BigRed922's Avatar
Already did that and they dont fit. The still rub. Any other things?
Old Dec 17, 2012 | 9:44 PM
country_09's Avatar
What truck/lift/tire size are we talkin bout here? Along with rim size and rim width/offset
Old Dec 18, 2012 | 10:11 AM
BigRed922's Avatar
Trucks an 02 silverado 2500hd. I cranked my keys up about 5 turns and it sits leveled now. The tires are 285/75-16 width is 8.5. Tires rub the bumper and im thinking about extending the bumper out. I can provide pics if that helps
Old Dec 18, 2012 | 6:34 PM
country_09's Avatar
Crank more and add a block in the back to lift it another inch all the way round or so. What's the offset on the rims?
Old Dec 18, 2012 | 7:27 PM
BigRed922's Avatar
how difficult is it going to be to do blocks? can you direct me to a site that sells them? im searching now and keep coming up with full on 6in lifts.
Old Dec 19, 2012 | 5:24 PM
country_09's Avatar
Blocks are super easy. Just go to a junkyard and get some 1.25" blocks from a 07+ 1500 silverado and then get new u-bolts from a lift shop or have a parts store make you some
Would be the easiest way to go about it
Old Dec 19, 2012 | 7:19 PM
ToooTall1's Avatar
Cut the black bumper moulding on the bumper bottom. On each end cut from top where it connect to bumper and cut towards the bottom of moulding on an angle of 1 to 2 inches towards the front. That will give you clearance for your tires. My 2001 2500hd with 285x75x16 have no problems with clearance after the mod. Send picture if you can
Old Dec 20, 2012 | 2:30 PM
BigRed922's Avatar
QUOTE]
Heres the pic. Il need to cut an inch or so. I dont thibk lifting it another inch will help
