No oil pressure and bad knock
Old Jan 10, 2013 | 1:59 PM
Michael Gillitzer's Avatar
Exclamation No oil pressure and bad knock
I have a 2003 Sierra with a 4.8l and a problem. It has 123505 miles on it. Yesterday morning I went to start my truck for work and it responded with a horrible knocking sound and no oil pressure. I Immediately shut it off. After work I went to look at it a little further and started it again. This time I was able to narrow the knocking noise down to the drivers side bank. All the plugs from that bank are covered in oil, even to about halfway up the threads. All of this happened very suddenly. It ran perfectly fine the day before yesterday, took a crap on me yesterday. HELP!?!?
Old Jan 10, 2013 | 2:55 PM
branndonn's Avatar
Then my friend you just have a knock in the engine , where it comes to the spark plugs with oil that's normal , they get covered pretty good from the valve covers , but other then that could be a knock or your lifter..
Old Jan 10, 2013 | 7:24 PM
My worry is that the knock is VERY loud. I forgot to mention that I have DTC codes saying that I have multiple cylinders misfiring, and knock sensor 1 low input
Old Jan 11, 2013 | 3:07 AM
branndonn's Avatar
Other guess for me that you probly have a broke piece of carbon in your cylinders
Old Jan 11, 2013 | 7:48 PM
budmuddy's Avatar
Possible o-ring failure on the pick up and oil pump connection?
Old Jan 11, 2013 | 9:49 PM
MDTAHOE's Avatar
Professional Mechanic
If you have no oil pressure and a knock you most likely need a new engine. Did you check to see if the oil level was correct? It is possible that the engine burns oil and there is no oil left.
Old Jan 18, 2013 | 5:48 PM
this is from the #6 cylinder... I'm guessing rod bearing?
Old Jan 18, 2013 | 5:50 PM
and the engine does burn oil, around 1qt per tank or 2, but i keep on top of it and it was 1qt before the fill line on the dipstick.
Old Jan 18, 2013 | 8:23 PM
SnoDrtRider's Avatar
That looks like pieces of melted Aluminum?
Here is what I just went through with an oil pressure problem on a 4.8...
https://chevroletforum.com/forum/exp...r-noise-55524/
Old Jan 19, 2013 | 2:14 PM
Well I found the source of my issue. This is the picture of my #6 Cylinder. This is exactly how it looked when I pulled the head from it. completely "ate" the piston.
