No Power to FSCM
No Power to FSCM
Hi everyone.
I have a 2012 1500 LT with the 5.3 V8. Recently I've been having issues with the truck stalling. I've had a new Delphi fuel pump installed and a new AcDelco FSCM installed and programmed. The truck is now cranking, but not starting. The MIL is lit. My code scanner will recognize that there is a code, but it just reads N/A instead of giving me a number. I tested the connector to the control module with a voltage light and none of the wires lit up with either the key on or off, including the power wires. I tested all applicable fuses under the hood with the light, as well, and they are good. Has anyone had this issue? If so, what turned out to be the culprit? I figure I'm down to wiring or the ECM.
Thanks in advance!
Thanks in advance!
Disher Performance
Camaro
January 15th, 2013 5:34 PM
