No spark after swap..
Old May 22, 2011 | 1:23 PM
wmiller1337's Avatar
Default No spark after swap..
Ok, so I swapped my slowing dieing 4.3 and dead 4l60e with a younger pair from another truck. The pair ran fan in the wrecked truck they came from.
After doing the swap, I am getting no spark. I am getting power to the ignition coil and spark coming out of the coil to dist. wire. However I am not getting any spark coming out of the spark plug wires. I have tried both the rotor/cap from the new motor and the rotor/cap out of the old engine that I KNOW are fine. Dist. is the known working one from the old engine, and it IS spinning. Dist. is plugged in, so what else could give??
Old May 22, 2011 | 1:45 PM
Whoops, let me clarify that. I am not getting a SPARK out of the coil or coil wire, but I am getting a voltage reading. No voltage out of the spark plug wires though.
Old May 22, 2011 | 10:15 PM
Problem solved. For the archives, it was the crank sensor. Troubleshooted it down to the crank sensor and replaced it with the old engine's sensor and that fixed the spark issue.
mamulan
Aug 20, 2014 8:39 AM
stdhawaii60
Dec 24, 2010 11:14 AM
catill
Aug 30, 2010 11:07 AM
PastorK
Mar 6, 2010 6:55 PM
