No speedo or tach
No speedo or tach
I have a 2000 Silverado and I have lost the speedo, tach and the transmission indicator light, not sure what else. Anyone have an idea , can't seem to find a fuse for that.
Any help would be appricated. I am a long way from anyone who can fix this for me.
2000 new body style or 2000 old body style?
are the gauge needles resting on the lower stop or stuck in any random position.
What is a transmission indicator light?
the fuses should be labelled in the owners manual. The cluster fuse is probably labelled IPC fuse.
New style
The gauges work find no lights except check engine light. The transmission light I referred to are the Park Drive and reverse indicators.
I am now having the problem of the engine stopping at random intervals. I mess with the relay and it will restart but may not keep running. I have replaced the fuel pump many times but in the passed it howles before it quits. I am in the jungle in southern Mexico and can't get it runing well enough to make the three hour trip to town.
any help would be great
You need a new cluster. There is one good thread on this site about repairing the cluster. I will try to locate it if you want to attempt this.
Post the doc that is set in reference to the other problem.
